My Xantia didn't come with a owners handbook and i can't find out what a couple of the buttons do. First is the button to the right hand side of the steering wheel that looks like a speaker with 2 lines through it? Second is the button with a snowflake on it next to the rear heated window button in the middle of the dash.
Cheers
Xantia:- Buttons on the dash
jgra1
- (Donor 2021)
- x 36
Re: Xantia:- Button's on the dash
Alastair, first is the internal ultra sonic alarm detector disable.. i.e. if you want to lock and alarm the car, but leave the kids, dog in..
I think it disables those movement sensors only
second should be air con
John
John
Xaccers
- x 188
The one by the steering wheel disables the cabin alarm sensors
The snowflake is aircon. It needs enough gas in the system to activate.
DIY sphere tool
DIY sphere tool
- x 8457
The first is the ultrasonics over-ride button. Push it until the alarm LED glows solid after the ignition is off and then when you set the alarm on the plip the alarm will be set with the ultrasonic movement sensors deactivated. Also, this button acts as an alarm reset. Typically then reconnecting the battery the alarm will set. The alarm may be reset by holding down this button whilst turning on the ignition.
The snowflake button is your aircon switch. Push it in until it illuminates and your aircon compressor should engage...
alastair70
Thanks for that chaps, I'll have a play sometime
citroenxm
- Fallen Hero
- x 70
Sorry I have to laugh, three people ALL jumped on the topic and answered within minutes of each other with the same answer..
Very good..
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8457
We were all feverishly typing at the same time Paul!!!!
Dommo
- x 20
Re: Xantia:- Buttons on the dash
The first one is your...
Ah never mind, I was a bit slow with that reply
Jaspwieser
wow, i have the manual and the alarm overide button is not even mentioned in it. i know cause i looked to see what it did too
J
J
Richard
Xantia 2.0 hdi estate (Y REG)
C5 2.2 HDi estate (in a stupid purple colour)
