C5 2.0 8V HDI oil leak
davo77
Unread post by davo77 »
Hello everyone,got slight leak on right hand side of engine as you look under bonnet,seems to be coming from rocker cover/inlet manifold area have cleaned said area . Anyone got any ideas/tips on Rocker cover gasket replacement or inlet manifold gasket replacement,any other known leaks in this area i can check ? thanks
C5 lx 2.0hdi 04 114k, Saxo 1.1 desire 02 83kk,Peugeot 3008 1.6hdi Active 17k
x 8395
Re: C5 2.0 8V HDI oil leak
It's worth checking the oil filler cap is good. The rubber seal in it goes to a horrible gooey mess and stops working. I had to replace the cap on my HDi and was staggered to find my local Stealer keeps them in stock because they fail so often...
davo77
Hi not filler cap looking from top right near bulkhead it is wet on rocker gasket seal and on inlet manifold right hand cylinder,there is also oil mist under sound proof cover. The leak is'nt massive just needs sorting out,assuming it is blowing around this area and making mess.
mlkey
Unread post by mlkey »
Had the same on mine. it was leaking where the little breather tube leaves the rocker cover and goes to the air intake pipe. The pipe will be solid and in need of replacement I suspect.
davo77
Hi now area is clean had a run and it is coming from inlet manifold gasket with oil making its way up to rocker area.Any advice on difficulty of repair,anyone else had to renew this gasket.Assuming oil mist gets into air pipes after intercooler and escaping,could be why MPG is only 43 :(
