My car failed the Nct on the front windscreen washers not working ,the rear works fine and sprays out but the front doesn't, all the pipes seem fine and are all connected at the front.
It was workin fine up until recently,i just haven't needed to use it
It's not the pump because the rear wouldn't be working if it was that ?
Is there anything else i should have a look for ?
Dave
Windscreen front washers
XantiaDaveEire
- x 4
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k
DickieG
- Monaco's youngest playboy
- x 38
Re: Windscreen front washers
Look for a kink or break in the hose where it passes by the bonnet hinge on the O/S.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Diabolical
They could be blocked? If they are poke some thin wire into holes but be careful you don't ruin alignment as they will squirt over the roof.
06 C5 2.0L HDi Exclusive Estate 20020k and rising.
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
citroencx.co.uk
Dommo
- x 20
I'm sure a lot of pumps have separate front and rear washers, my brothers S2000 has different sections of pump, one does the windscreen and one does the headlights, off the same pump/reservoir.
the_weaver
Pump the washers and check for leaks where the pipe is pushed onto the non-return valve(s). The pipe sometimes hardens where it's stressed by stretching over the valves. If it leaks, you can usually fix it by cutting a bit off the end and re-making the connection.
You might have an air lock. See if the washers work when the bonnet is in the up position. It might start working because the angles that the water is flowing along are different. If it starts working, then it could be an airlock caused by a leak.
Paul
Paul
ZX 1.9D, 1993, 218K.
XantiaDaveEire
- x 4
Fixed it
The connecting pipe had come loose and was just spraying water out on the engine instead of doing its job
Dave
Dave
the_weaver
