Hi all,
Picked car up today from its MOT and one of the advisory's was that the aux belt had tensioning issues, and the head garage owner said that the belt was flapping up and down a bit. It had a brand new belt and tensioner about 8 months ago and according to the garage the tensioner is fine and the belt is in good condition. The garage said they were too busy too investigate further. But he did said the one thing that could be causing it is the clutch on the alternator pulley.
Has anyone had this problem and was it the cluth on alt pulley? If was it easy to change and did it cost much? I usually do my own spannering, but recently I have been so busy I have not had chance to check the car over like I normally do especially before a MOT.
Thanks for any advice,
Cheers,
Shaun
Xantia SX 1998 1.9TD XUD Flapping Aux Belt
red_dwarfers
- x 58
Re: Xantia SX 1998 1.9TD XUD Flapping Aux Belt
Something else that might be worth looking into is the actual spring itself, as the eyes at either end can wear. When people and garages say they replace the tensioner, they usually just mean the actual wheel and lever thingy that connects to the spring. Had this on mine, easy and fairly cheap to pick up at GSF and all.
Kev
'19 C4 Cactus 130 Flair
citroenxm
- Fallen Hero
- x 70
Xantia Altinator Pully are not "Clutch'd" they are a standard type..
Theres two possibilities here then... The eccentric tensioner may need re adjustment to take the excess slack out of the belt..
If you remove the inner arch liner - you may need to remove the upper engine mount to lower the engine, the SQUARE hole in the lower tensioner is at it tightest when the square is nearest the Crank Pully...
Theres also a posibility of the wrong length belt being fitted ...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Xaccers
- x 188
The eccentric tensioner is set simply by slackening it's hex bolt, letting the belt rotate it round and then tightening it back up.
If you need to force it round to tighten the belt then your auto tensioner spring is duff or the auto tensioner bearings have collapsed preventing it moving against the belt to tension it properly. Or the belt is too long.
DIY sphere tool
DIY sphere tool
citroenxm
- Fallen Hero
- x 70
That slackens it off xac... To set it correctly the eccentric should be on a HALF way setting for it to be right....
I think the bol also explains that procedure too.. Its how i set all of mine and never had a flapping belt... If its meant to be slack whats the point of it being an eccentric....?paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Xaccers
- x 188
I'm sure the BOL says to slacken the hex, then release the auto tensioner against the belt, which sets the tension on the belt, then tighten the hex.citroenxm wrote:That slackens it off xac... To set it correctly the eccentric should be on a HALF way setting for it to be right....
Otherwise you're compressing the auto tensioner spring more than you need to by adding extra tension with the eccentric.
Mine's like that and not flappy.
DIY sphere tool
DIY sphere tool
marty1979
Morning! I just thought I'd chime in with my experience with this, only on a 2.1td 406. When I got the car it had just had a new aux belt, I had to replace it because I had the same flapping about at the bottom between the crank and air-con pulley, this eventually caused it to move across towards the engine and it lost a rib and sounded horrible. Anyway, I did the timing belt a couple of Fridays ago, I also replaced the aux belt....again, but it was doing the same flapping about at the bottom run. The auto tensioner has loads of spring in it, but I noticed that the pulley assembly was almost touching the engine, about 10mm away when released against the belt, so I turned my attention to the eccentric pulley that I had never touched before and it was at it's most slack position with the square hole towards the top of the engine. I proceded to adjust the pulley so that the square hole is pointing towards the crank pulley just as mentioned above and it's been perfect since. Hope that helps you guys.
citroenxm
- Fallen Hero
- x 70
Thank you marty for your input... I knew the eccentric was there for a reason and i wasnt going mad...
Exactly what i do. And when i did that on my hdi (same set up but a far more sensible and user friendly spring tensioner) 30k ago mine to has also been perfectly quiet..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
the only clutch involved here is for the air con pump pulley this might be what the garage ment/said,
regards malcolm
regards malcolm
