Re C5 2.2Hdi 2002, underpowered and will not rev past 3500 revs and going through a lot of diesel.
FAP cleaned out.
Eolys topped up and reset.
Lexia says Air flow fault and air temp flow fault.
Tried a new MAF sensor - still the same. Possibility one of the vacuum pipes is on wrong? Tried disconnecting turbo electro valve and disconnecting swirl valve from ball lever and pulling swirl valve up.
Could a leak in one of the vacuum pipes cause this sort of power loss?
Please can anyone suggest more?
Ally
