C3/Peugot 207 wheels to fit S1 Xantia?
Xantidote
x 5
Unread post by Xantidote »
In my quest locally for some spare steel wheels, I've come across a new Peugot 207 with 185/65/15 tyres, same as my Xantia, which suggests to me that the wheels are probably 5 & 1/2J. Does anyone know what offset the 207 would have?
In a similar but more promising vein, I've come across adverts for 15" C3 wheels with 185/60/15 tyres, so again assume to be 5 & 1/2J. Anyone know what the offset would be? Presumably could vary dependent on model & age?
Cheers - Martin
Martin
1995 Xantia TDLX (deceased :( )
Duracell
Re: C3/Peugot 207 wheels to fit S1 Xantia?
Unread post by Duracell »
C3 appears to have an offset orf 15-25mm as opposed to the Xantia 15-20mm - other dimensions are the same, so I would have no doubts about fitting them - not sure about the 207 as it is not on my listed on my PCD chart, but suspect it will be the same as the C3
Xantidote
x 5
Thanks Richard :)
Martin
