The height selector lever seems to be loose when in the middle (Driving Mode) it doesn't click and lock as it should, when selecting Low or High mode it doesn't go til the end but it locks and car rise and fall normally though.
Thanks.
Height Selector Lever
VertVega
- x 13
Re: Height Selector Lever
Never experienced or heard a similar case but it might be worth checking the spring which is attached to the level selector handle.
For a quick check you can remove/lift the plastic dust cover strip. It is the one which has wave form surface.
