Recomended screen wash
c.morewood
x 55
Unread post by c.morewood »
At Lidls now, screen wash with antifreeze 5lit for £5.99.
I used this neat last year all through the winter and even at -20C it didn't freeze in the jets!!!
In fact I last filled it neat in March and in summer all I've done is top it up with water and its still soapy!!!
Hope this helps.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
spider
x 77
Re: Recomended screen wash
Unread post by spider »
That's a good price. :)
Is it not bad for paintwork when neat though ?
Although having said that, when new they just have a bit of neat screenwash put in the washer bottle. Its filled with water at PDI
Andy.
ACTIVE8
x 6
Unread post by ACTIVE8 »
spider wrote:That's a good price. :)
Not exactly!
They try to get away with doing that also.
All levels are allways as little as they can get away with, and have to be corrected by the dealer, and the tyre pressures have to be corrected as they are pumped up a lot higher, to stop flat spots forming during the times when the vehicle can, and will be standing for long periods of time.
If the vehicle come from abroad it stands around at the factory car park, dock side, on the ship, at the dock when it arrives, at transportation storage areas on route, at the dealer etc,
At the PDI they get brought down to the correct pressure, and all the fluid levels go up to where they should be.
ACTIVA
Xaccers
x 188
Unread post by Xaccers »
I've moved this to the French car chat section as it's not specific to Citroens
DIY sphere tool
ACTIVE8
x 6
I agree with that comment, because it's not intended to be used undiluted, if it were then when mixed with the water it would be too weak!
ACTIVA
x 1500
I've got about 12.5 litres left in the garage from last winter - once I started using it (at 30% conc) no more problems with frozen washers, even down to below -15 we had last winter. The only problem I had with it was breaking the windscreen in the Picasso! Son was asleep in the car, so left then engine idling for about an hour, then we went off out. Washed the screen (it was -10 at the time) and it cracked right across the middle - from a tiny chip in the middle #-o
