Xantia Door Locks
alastair70
Xantia Door Locks
Unread post by alastair70 »
Hi Guys,
I've just bought a 95 xantia, and found out that i can't lock it!! I put the key in and it turns a full 360 degrees in the lock, with no resistance or as if it is doing anything at all. This happens if the drivers, passengers & boot lock. If i sit in the car and lock the car from inside the central locking works on all doors. Does anyone have any ideas how to fix it please? Also the radio is asking for its code which the previous owner had lost, how or where can i get a new code please?? All help gratefully received
Cheers
x 8457
Re: Xantia Door Locks
Hi Alastair, welcome to the forum and to Xantia ownership :D If all the lock barrels spin then it's the wrong key. It's how it works. The right key will do the business but any foreign key causes the barrels to spin right round. It can be a sign of a worn lock too but normally only the driver's side shows this up.
I would hazard that the ignition barrel has been replaced at some time and last owner failed to give you all the keys...
Radio code is no problem at all. PM me the FULL serial number of the radio, found on the sticker on the side of it, and I can decode it for you...
If you're not sure which is the serial number, just send all the numbers you find on the white label...
bxzx16v
x 34
Unread post by bxzx16v »
If you can remove the lock cylinder and take it to a locksmith they should be able to cut a key to the barrel for you , or rebuild your cylinder to match your ignition key . Just had to have some cylinders rebuilt on my dispatch and their like new now , one key works every door !
Mark
alastair70
Thanks for the advice, is there a guide on how to remove the lock cylinders so that a locksmith can cut a new key? I've been having a look on Ebay for a new lock but their not cheap. Does the remote fob work if you reprogram it, as they seem alot cheaper? I've just found a guide on how to reprogram the remote fobs on Honest John's
bxzx16v
x 34
Not sure about the remotes , Jim will know I'm sure , I paid £15 for each barrel to be rebuilt so not bad compared to new ones . The xantia door panel is fairly straightforward to remove , I'm not sure on access to the lock/handle though , once disconnected from the handle/mechanism there is a spring clip/clips on the cylinder , once pushed the cylinder should push out , hope this is of help
Mark
