leakoff pipe acess !
froggy
- (Donor 2026)
- x 4
Hi, I have just been trying to fit a new leakoff pipe, on my 1997 XANTIA. The pipe appears to go from the pump to the side of the injector [ furthest left ] My question is; acess is poor there is a hard plastic pipe [ air intake to turbo] inthe way. can I move it? Plus the inner diameter of the new pipe seems too small or is it supposedto be megga tight? many thanks Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 8457
Re: leakoff pipe acess !
Hi Terry, yes, if you loosen the hard plastic turbo pipes at their securing points and disconnect their rubber pipes at the jubilee clips, they will move quite a way to give access.
Yep, the leakoff hose is a tight fit as it relies on only that for sealing... Also, replace the end blanking cap on No.1 injector but those you get in some kits are of questionable quality. I used to take a piece of normal leakoff pipe, bend it in two at the end and wrap a large cable-tie around it. That made a very effective blanking cap that was long-lasting and very cheap as it used up some surplus pipe...
froggy
- (Donor 2026)
- x 4
Thanks again Jim.
Terry
