rear end rattle
citroenxm
Fallen Hero
x 70
rear end rattle
Unread post by citroenxm »
Hi all..
Car in question.. Xm S2 2.1 td auto hatch..
Car came to me for a routine check over and fit some spheres.. Rear spheres, all 3 thats the two corners and a centre sphere were ordered from AEP Glasgow.
I got them fitted and all seemed well.. For about a week... The owner then started complaining about a rattle comming from the rear.. The spheres were date stamped with 2010 so were new. So we got under the car and looked about.. I found what looked like a loose connection between the strut and arm fixing point so set about changing the rear arm and strut.... After re fitting everything the rattle remained... Cause?? It turned out to be the spheres!!!! Really!!
I put some older 2003 spheres on and way hey the rattle went away.. Im not sure why but its not the first time ive experianced this.. I had it about fout years ago on a front sphere on a xantia..
Paul
A very sad...
1994 XM 2.1 d auto
x 8457
Re: rear end rattle
That's odd Paul :-k
Can't think what could cause that unless one of the corners was flat...
Strange...
x 1240
Re: rear end rattle
Unread post by Peter.N. »
That's a strange one Paul, sounds as though there is some air trapped in the sphere - can't understand how though. What a pain having to do all that work!
x 8457
Re: rear end rattle
Wonder if it's a loose damping element?
citroenxm
Fallen Hero
x 70
Re: rear end rattle
They were far from flat as the car had a beatufully nice ride.. Smooth and soft...
Anyway.. Cause found.. Be suspect of spheres!!!!!
Paul
A very sad...
1994 XM 2.1 d auto
robert_e_smart
x 14
Re: rear end rattle
Unread post by robert_e_smart »
That is strange. I have never encountered that, nor do I want to!!
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
x 94
Re: rear end rattle
Unread post by citronut »
is the ride as soft now you have fitted diferent spheres,
as maybe it was somthing linked to being so soft causeing something to rattle ?????
regards malcolm
citroenxm
Fallen Hero
x 70
Re: rear end rattle
Yes the ride is just as good.. It WAS the spheres... Had the same on a xantia... That too was a sphere..
Paul
A very sad...
1994 XM 2.1 d auto
