My sons van I posted about some time ago with regard to the injector pump which with the help of donated parts by JIM we rebuilt and got running again, only to be shot down in flames when the front pulley smashed into bits and broke the camshaft in 3 pieces whilst over taking another van,(put another engine in)
My sons van has without warning broken the outer cv joint
£20 later a new cv joint dropped through the letterbox complete with rubber boot, boot clips,tube of grease and circlip type thingy.
I am now 50 and have been tinkering with vehicles for a long time and quite confident and sometimes clever when it comes to repairs.
But for the love of god why have I only just found out cv boots do not need to be s t r e t c h e d to the max to go over the cv joint
Dismember the driveshaft from the hub make up a suitable drift and tap the outer cv joint off the shaft slide new boot on grease and put back together simples.
His was apart and being put back together within half an hour. Altough the outer cv we got was for the abs model and the driveshaft nut is not deep enough to have the spring clip hold it in place so we used the old one.
Is this the same with all driveshafts or are we lucky that these driveshaft cv joints can be easily replaced, I must be mad the hours I have spent changing cv boots in the past even tearing new boots cos I just stretched them to far,lost god knows how many layers of skin from my knuckles, Am I really that THICK that I could'nt work it out in the 34 years i've being tinkering.
And cos I have a split cv boot on mine It wont take long !!!!!.
No not if the bloody 36mm nut does actually come undone,mine did'nt and broke my bestist breaker bar f##k.
Drilled 6 holes in the nut to get some heat into it and broke my bar
I even had a 6 foot scaffold tube on it once to undo the driveshaft nut on a montego now its dead,well the knuckle anyway.
So the moral is check to see if the cv joint can be knocked of the shaft before you go stretching the crap out of the rubber boot.
Sorrymore of a rant really I miss my bar
