I have just changed all 6 spheres on my 110 bhp HDI estate 1999 model(non hydractive)The car rises and falls a lot quicker now but when raising from low to normal or high the low pressure system light comes on. I have the flush oil in at present an know it is a thinner viscosity but why am I getting low pressures?
Thanks, Mike
Xantia suspension
iancook2000
mike davies
Ian,
thanks for the reply but I checked it this morning and it is correct. The car has done only 26,000 miles when the ride went all hard. the fluid was very dark green but the filters were reasonably clean.The stop lamp and the fluid level/pressure lamps used to take 30 sec's to go out from start up in the morning. They now go out in 2 sec's flat. The steering had become less notchy as well. The symtoms do not seem to point to the pump. Any other ideas would be appreciated.
thanks Mike.
thanks Mike.
nevorton1
