C5 spheres where to buy?
waynedance
x 8
Unread post by waynedance »
In my quest to get rid of the road noise which is loud on rough roads at slow speeds I have so far replaced drop links, bottom arms and the rear bushes.
The thing to try next is the spheres, where is the best place to buy and best spec.
Thank you.
Ps mk1 2003 2.2 hdi exclusive done 75k
Citroenmad
x 110
Unread post by Citroenmad »
Is it just tyre noise your trying to eliminate?
I can't imagine spheres would have any effect, however tyres do have a massive impact on road roar and noise.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
waynedance
x 8
Tyres are Kuhmos on all corners so no budgets. The noise is loudest on worn road surfaces at slow speeds and is like a vibration rumble.
Tried removing under trays, tightening arch liners. Tyres are Kuhmos on all corners so no budgets. The noise is loudest on worn road surfaces at slow speeds and is like a vibration rumble.
Citroenmad
x 110
Has the noise started recently, been progresive or always been there?
The C5 usually is very quiet with road noise, so somehting is not quite right.
Spheres will give a poor ride if they are low on gas but won't effect the road noise. However if you do need to replace them then try AEP parts (search google for their website) or GSF. Obviously they are available from Citroen to get the correct spheres but they will be pricey.
03 Seat Arosa 1.0S
waynedance
x 8
Noise has been there since I got the car a year ago and 15k. was think wheel bearing but noise not there at speed.
waynedance
x 8
Can I do the spheres myself with no diagnostic plug on machine?
Thanks.
pete@co.uk
Unread post by pete@co.uk »
Yes you can do them yourself and you don,t need any electronic tools but you will need a strong chain or strap wrench or a special tool for removing the sphere,s as they are very tight
Pete
Drives
51 Reg Citroen C5 SX 2.0 16v
waynedance
x 8
Is just put on lowest setting and unscrew them and fit new ones and add fluid?
Citroenmad
x 110
waynedance wrote:Is just put on lowest setting and unscrew them and fit new ones and add fluid?
Pretty much :)
Ive found C5 spheres to be very very tight and as they are a wider sphere they don't fit in a lot of typical sphere removal tools.
03 Seat Arosa 1.0S
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Citroenmad wrote:Ive found C5 spheres to be very very tight and as they are a wider sphere they don't fit in a lot of typical sphere removal tools.
As I understand C5 saucers aren't rechargeable I'd have thought that using a chisel on the circumference would do the job especially as its wider than traditional sphere's so more leverage on the thread, not exactly a scientific method but effective.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Citroenmad
x 110
Apparently some people have drilled the spheres to allow for a recharging nipple to be screwed into the end. Ive not looked into this but it was mentioned on here a while back, I think it might well be over on the XM forum for some reason.
Though I doubt I would try it and yes C5 spheres are scrap once finished with, so as long as you can get them off then using the chisel method would be an idea.
03 Seat Arosa 1.0S
SaabC5
Unread post by SaabC5 »
What tyre pressures are you running?
x 1240
Unread post by Peter.N. »
Not low profiles are they?
Citroenmad
x 110
Ive not had Kumhos on a C5 but they are usually quiet tyres.
Some tyres which have been fitted to C5s ive bought have been very noisey though.
03 Seat Arosa 1.0S
waynedance
x 8
Had budget Tyres on when got car so changed them and noise still same. Pressures are as the label states on door shut label.
Volvo S80 D5.........
