can a c5 be driven with a wheel missing?
sonoramicommando
x 5
Unread post by sonoramicommando »
Ok - silly question time.
I've seen clips of GS & DS being driven with one rear wheel missing (in fact, one clip was an actual TV ad for GS, doing a slalom).
I'm curious to know if C5 is capable of doing that.
cheers,
Sam
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
x 5688
I wouldn't like to try it with mine!
Never dared with the GS either, or the BX or Xantia.
But apparently there are a couple of American cars that can do it, as can some older SAABs.
It isn't the hydraulics that make it capable but the double wishbone suspension, so I have read anyway.
The McPherson struts aren't capable.
sonoramicommando
x 5
Ha ha I wouldn't want to try it either, to be honest.
Here are what I found after a quick search on YouTube:
Xantia (& GS & CX) - seems like this guy really likes three wheeling!!! :lol:
GS - this is funny:
GS TV Ad:
and DS (or ID - I don't know enough to be able to tell the difference) on CHiPs
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
x 94
Unread post by citronut »
all the hydraulic cit's i have seen doing this was with the suspension fully up on high,
because with it pumped fully up it becomes ridgied,
the other tric that can be performed with hydraulic cit's is changine a wheel without useing a jack,
plut just the oposite wheel up on a curb, put susp fully up which should lift the other corner off the ground,
if it doesnt you will be able to tip/rock it with one finger
so i dont see why its not possible with any hydraulic citroren, even the no full blooded C5 :shock:
regards malcolm
cachaciero
x 9
Unread post by cachaciero »
Could certainly do it with a CX, once broke an alloy front wheel at some speed, taking evasive action which curbed it, large lump out of alloy and tyre shredded, car steered perfectly only had to apply some correction when braking amazing, don't even like to think about it in a C5.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
x 1240
Unread post by Peter.N. »
You could quite easily drive a CX with a flat front tyre, initially without even knowing it, doesn't affect the steering at all, on account of the central steering knuckles - guess how I know :? :shock:
mongoose100
Unread post by mongoose100 »
I'm guessing it's able to hold its own when stopped with suspension on high but once you start moving and the computer decides to lower her down to normal ride height, you'd be greeted with the sound of your rear rotors getting a hiding from the pavement...
I know the Xant's can *just* keep the disc off the ground with the jack removed and suspension on high (tried once) but that is only about an inch max!
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
x 94
well the XANT is the very last full blooded hydraulic citroen,
i had a flat N/S rear tyre on my old AMI 8 years ago, 4 up including me driveing,
on route back to Whatlington garage (when it was H G Havaux's )from the cafe after lunch, my N/S rear passenger (Dave fnow from Marsh citroens ) was the first to notice,
when i pulled over the tyre was completly shreaded,
regards malcolm
dnsey
x 19
Unread post by dnsey »
Had a motorway-speed blowout many years ago on a GS, from a bit of 'shrapnel' on the road. Apart from the 'bang' from the tyre as it went, there wasn't much other evidence, and it was easy to slow down and pull over at leisure.
red_dwarfers
x 58
Unread post by red_dwarfers »
I always had the idea that the Activa could pull the trick off.
Kev
'19 C4 Cactus 130 Flair
Dippy
Unread post by Dippy »
A canine can sit on the pavement , raise a leg skywards , then lick it's nuts to oblivion ....
I'm still trying ...........
Citroenmad
x 110
Unread post by Citroenmad »
The C5 CAN NOT be driven with a mising rear wheel, I have tried this, it doesnt work. Well it does but there is grinding noises as the brake disc protector meets the floor. I tried it in my garage and while the disck protector wa sjust off the floor, while driving backwards and forwards it met with the floor a few times. If that was not on, it would be able to manage it.
Im not sure why It can't, perhaps its to do with weight distribution, im not sure.
The only way any Citroen will do it is if the suspension is on high, otherwise the cars suspension travel will simply take up the gap left by the wheel and force the disc/protector to the ground.
In theory an Activa should be able to do this, as the front side to side height corrects should keep the front level and so keep the rear missing wheel high off the floor. Ive yet to try this with my Activa.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 5688
Citroenmad wrote:The C5 CAN NOT be driven with a mising rear wheel,
Unless it's the spare :twisted:
