Check strap checked out and unchecked?lol
dieseldoggy
Unread post by dieseldoggy »
How do you check strap back into door fitting? As just been doing the est thing of rewelding lower hinge back on?
Replacing door(removed wing etc)mate said better push it in so outta way moving it round to try to push back and it came out of spring loaded slot!
So now it stops it opening to far? but no click half way/keeping open thing.
My way of thinking was i need to remove door pad and get inside from there with the attendant problems off bits in there getting in the way?
xantia 19td estate 96-7
