I have had a look around but cant find the glovebox fuse board layout.
There are a couple of fuses missing (or not needed) and would like to know what all the fuses are.
Got the van as a non runner,after taking the head off it has a broken valve which has made mincemeat of the head and piston so I Just transplanted an engine into it.
Any pointers on the fuse layout would be much appreciated.
98 dispatch fuse box
bxzx16v
- x 34
wotwot
- (Donor 2021)
- x 4
bxzx16v
- x 34
Here's some info out of the Citroen Dispatch handbook about the fuses ,
Fuse no 1 not used
Fuse no 2. 10amp diagnostic socket,Abs control unit ,reverse lights,heated mirrors
Fuse no 3 Not used
Fuse no 4. 5amp instrument panel,overspeed buzzer,speed sensor,water in diesel filter detector
Fuse no 5. 15amp Cruise control,brake switch,clutch switch,brake lights
Fuse no6 5amp Courtesy light,instrument panel,audio equipment
Fuse no7. 30amp Heated rear screen
Fuse no8. 30amp Passenger compartment protection unit
Fuse no9. 5amp Passenger compartment protection unit
Fuse no10 Not used
Fuse no11 5amp Fan assembly,compressor relay
Fuse no12 10amp Electric windows,air blower relay,heated rear screen switch,air con,pressostat
Fuse no13 15amp Hazard lights
Fuse no14 30amp Electric windows
Fuses 15@16 not used
Fuse 17 20amp Horn
Fuse 18 10amp Rear foglamp
Fuse 19 5amp Cruise control,lights on buzzer,instrument panel lighting,audio equipment,heated rear screen switch,hazard lights switch,air con control panel
Fuse 20 5amp Headlamp height adlustment switch,front left & front right sidelights
Fuse 21 5amp Rear left & rear right sidelights,numberplate lights
Fuse 22 Not used
Fuse 23 20amp Lighter
Fuse 24 10amp Audio equipment
Fuse 25 10amp Lights on buzzer,electric mirrors,indicators
Fuse 26 30amp Windscreen wipers timer,wipers,wash wipe pump
Fuse 27 Not used
Fuse 28 5amp Instrument panel,electric windows relay
The fuse numbers should be numbered in the fuse box , my dispatch is a 2006 2.0 Hdi 110bhp , great van , hope this is of help
Mark
Fuse no 1 not used
Fuse no 3 Not used
Fuse no10 Not used
Fuse 17 20amp Horn
Fuse 22 Not used
Fuse 27 Not used
Mark
wotwot
- (Donor 2021)
- x 4
bxzx16v
- x 34
