xantia main beam failure
reservex
xantia 1.9td main beam failure, i recently lost the near side main beam, checked the bulb which was ok, now the off side has stopped working, anyone any experience of this?
1999 Xantia Estate 1.9TD
RussellF97
- x 10
VertVega
- x 13
reservex
i checked the bulbs when the first side went out and both ok, led a wire from the working side and both beams came on, now nothing could it be a suspect feed or if its the fuse where is it?
VertVega
- x 13
