Factory supplied Xantia Alloys quastion.
aerodynamica
x 215
Unread post by aerodynamica »
Hi all, simple question: do the factory 15" alloys for the Xantia (those fitted to VSXs) need special wheel bolts? (or can the same bolts as used for the steel wheels be used with no ill effects or dangers)
Best,
Graeme 8-)
Graeme M
Citroenmad
x 110
Unread post by Citroenmad »
Ideally they should have the alloy wheel style bolts, with the washers on them as the ones for steel wheels might not seat correctly.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
aerodynamica
x 215
Right gotchya.
Next Q. Where does one get such items?
Graeme M
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
As Chris says they do require different bolts with a washer, standard steel wheel bolts are also too short for thicker alloy wheels.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1438
Unread post by xantia_v6 »
Some (I think pre-97) VSX alloys use countersunk bolts, but these are still a different length to those used for steel wheels.
Using countersunk bolts on wheels intended for flat olts would probably damage the wheels.
MTND
Unread post by MTND »
aerodynamica wrote:Right gotchya.
Hi Graham
I forgot to give you the wheel nuts to go with the wheels, I thought I had but I when I got home from the CXM they were still in the boot! :(
I you're in Cambridgeshire any time you're welcome to have them?
Mark
1995 Xantia 1.9 TD SX owned 17 years
Alfa Romeo 916 GTV Spider 2005
Ford Focus Titanium X 2017
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Ebay - BUT the thread and shoulder parts do come in different lengths....
Paul
A very sad...
1994 XM 2.1 d auto
Citroenmad
x 110
Hi Graham
Mark
Ah, good to see you on here Mark, I didn't realise you were an FCF member :)
03 Seat Arosa 1.0S
aerodynamica
x 215
Hi Graham
Mark
Hi Mark, cheers! Not sure I'll be in your neck of the woods any time soon but the wheels are still short of tyres anyway!
Graeme M
x 8281
Citroenmad wrote: Ah, good to see you on here Mark, I didn't realise you were an FCF member :)
Nor me... Indeed, it's Good to see you Mark :D
red_dwarfers
x 58
Unread post by red_dwarfers »
Ah, hello much whiter Xantia man!
Kev
'19 C4 Cactus 130 Flair
