Yet another radio coding problem
isisalar
x 3
Unread post by isisalar »
This is the Citroen branded 4030RDS model.
I've stupidly inputed the wrong code and my radio is now locked out & we're now at the 4 dashes stage.I recently left radio on for an hour which brought up the code display.Inputed code, back to 4 bars.
Some of the LED bars have gone missing lately, so I can't see some numbers in their entirety. When I inputed the first digit(which is 1)the display looked like it couldn't be a 1.Can you scroll through the numbers?
The other digits started from 1 & looked ok but the 1st one didn't look like a 1 at all,maybe an 8 or 9.
Hopefully when I go back out to the car, I'll be able to have another crack at it.
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
x 8457
Paul,
I've done one with most of the display missing..
When CODE is displayed, the first press of the corresponding button, say 1 for the first digit, will give a zero. Subsequent presses of the button will increment it..
Remember, button 1 for the fist digit, button 2 for the second and so on. press button 6 to enter the code at the end of entry..
If you need your code confirming, PM me the FULL serial number and I' can decode it for you...
isisalar
x 3
Thanks for the reply Jim.In the event,I managed to scroll through & put the right code in,was getting worried though.
Paul
