Where's my brake lights gone?
isisalar
x 3
Unread post by isisalar »
It was pointed out to me recently that only my high level brake light is working. I've just changed the other bulbs & still no brake lights working,high level ok, sidelights ok.
Any suggestions anyone?
My rear height corrector mechanism was lubricated, & the o/side handbrake cable was replaced earlier this week, which may have some relevance.
Thanks.
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
VertVega
x 13
Unread post by VertVega »
Hi, My guess is the brake wire broken is the outlet which goes from car body to the tailgate :roll:
To be even more "specific", I guess it is the one on the right side.
EDIT: In mine the auxilary brake light didn't work because of the above described reason.
Xaccers
x 186
Unread post by Xaccers »
Open the boot lid, gently pull back the rubber conduit on the passenger side and check in there for any breaks.
DIY sphere tool
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
As the problem is not with the central brake light I'm rather confused about the advice given in the above posts as the other two (non working) brake lights are on the car body so I presume the subject has been misread. Other than try another bulb change I'd get my volt meter out and start tracing back the earth and supply wires with the aid of a wiring diagram.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Xaccers
x 186
Ah I read it as the high level brake light was the one not working
DIY sphere tool
VertVega
x 13
Symptoms of reading disability :? ... Sorry.
Did you make sure it is a dual filament bulb?
Sl4yer
Unread post by Sl4yer »
Check the contacts on the car aren't oxidised. A good scrape with a screwdriver will usually provide a quick solution.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
isisalar
x 3
Thanks for the replies. I've had a look at the wiring where it goes into the tailgate and it looks ok, it also looks a very likely place for a break to occur. I am a complete duffer with electrics unfortunately.
Is there anyone within striking distance of north London that could help me with a diagnosis?
I could probably cope with replacing some cable but need to know which one etc.
Paul
xantiasmiff
Unread post by xantiasmiff »
I had the same problem a while ago and it turned out that i had replaced the brakelight bulbs in the wrong holes ! Both had blown. Double check. :)
DickieG
x 38
I'm willing to offer you a helping hand if you want to pop round, it shouldn't be too difficult to sort out.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 8275
DickieG wrote:it shouldn't be too difficult to sort out.
Says he, hopefully, fingers crossed.... :lol: :lol: :lol:
isisalar
x 3
Thanks for that.I'll be in touch.Can one pm here?
Thanks again
Paul
DickieG
x 38
isisalar wrote:Thanks for that.I'll be in touch.Can one pm here?
Thanks again
Paul
Yes.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
