Non-Automotive Electronics Question
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I'm trying to help my father who is quite hard of hearing.
He has a little piezo beeper timer that he uses for cooking - carries it in his hand or pocket while it's counting - however the range/volume are slowly slipping out of audible for him. That's even with a hearing aid factored in.
Wondering if I can drop the frequency of a piezo timer in any easy way, like by soldering a cap or resistor in? I can't afford to lose volume, though.
TIA for any suggestions. :)
OwenP
Unread post by OwenP »
From what I can see after a little digging on the net, the frequency of sound produced is a function of the frequency of power supplied, i.e. how rapidly the power supply to the piezo material is switched on and off.
From this website: http://justanotherlanguage.org/content/ ... orial_pwm2
Also according to the above, the duty cycle controls the output volume, although they appear to be talking about using a particular chip for the control (and this is a little beyond me at the moment.)
It is a long time since I've studied electronics, but from what I do understand of that page it may be more complicated than adding in a resistor or capacitor. A lot may depend on the circuitry that is already there and if you can access the control chip.
Beyond that I'm not having a lot of luck digging anything up and I never covered piezoelectrics during any of my electronics courses to fall back on other knowledge, sorry.
2001 406 Rapier 2.0 HDi 90 Estate - Sold Scrap after being viciously attacked by a falling tree
2001 Toyota MR2 1.8 VVTi - To be sold for spares/repair - dead gearbox :(
2014 Seat Ibiza Eastate 1.4 FR ACT (bought in an emergency, but a nice enough low mileage car)
HDI
x 7
Unread post by HDI »
Easier solution, buy him a flashing light or vibrating timer ?!
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 1481
Unread post by xantia_v6 »
It is a few years since I worked with this sort of stuff, but I think that piezo transducers are self-resonant, which is why they are so efficient. This means that you can't change the frequency much.
If you can find a suitable DC signal, maybe you can fit a vibrator unit from an old phone (old ones are best because they were designed to shake a phone with a lot of mass).
dnsey
x 19
Unread post by dnsey »
And usually fitted in a resonant cavity, too, in this sort of application.
Is there room for a physically larger transducer in the case?
addo
x 95
Not really.
I may just suggest he uses the iPhone's timer - covers all requirements.
