Rear height corrector problems
caspm
Unread post by caspm »
Hello.
I have a little problem with my Xantia 1.8 8v 95.
Yesterday when I set the suspension height control to max. the car raised as it should. Then to the min. and it lowered as it should. But when I set the suspension height control to normalposition it would not rais (from min.) og lower (from max.) Do anyone know what to do?
[:)] Casper
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
You're going to have to get under the car so get it up and well supported on axle stands. Have a look at the height corrector which is just forward of the spare wheel carrier. There's a small plastic clip fixed to ball joints. See if it's all attached properly. Give the moving parts a spray with WD40 and then with spray grease. Try to raise and lower the suspension several times. Your problem could be solved - but maybe not.
caspm
Dear JohnD.
Thanks. It seems to be a little plasticarm that controls the height, and it had fallen of. Now it works again, but I have to get a new one from the local Citroengarage.
[:)]Casper
