"And now for something completely different"
Anyone know of an existing, or has anyone made, a lift for heaving heavy things into the boot of a Xantia (or any other car?)
Have recently strained my back and need to collect some more of the same (bags of horse manure which must weigh 40-50 kg each, top of bag will tear when lifted unless v lucky) I was thinking of some kind of sling/winch arrangement supported from an upside down U frame located (not supported) by a peg in the tailgate latch, with weight take to boot floor by U legs.
After use it could then un-shipped easily.
But if such a thing already exists I won't have to invent it.
Boot load lift?
rpaco
Boot load lift?
1998 Xantia 1.9TD SX That kinda dark green that shows every spec and is an oven in the summer.
red_dwarfers
- x 58
Citroenmad
- x 110
Can you not rent a little trailer or something?
Probably easier on the back but certainly easier on the nose
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
dnsey
- x 19
rpaco
Ok thanks.
I am now trying to track down a device called the Backsaver designed by MidTech and supposedly sold by www.mangarinternational.co.uk originally for putting wheelchairs into boots.
- x 2941
Stepto1
mooseshaver
This any use ?
http://www.daysmobility.co.uk/Scooter-C ... n_lift.htm
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
- x 94
Clogzz
- x 40
ACTIVE8
- x 6
I like that one, if there was a stronger, or improved version of it then it would be even better.mooseshaver wrote:This any use ?
It has the potential to work well with an Xantia estate as the lack of lip unlike the hatchback would aid loading, although the hatchback due to the way the hatch operates gives more height clearance.
A version with extra capacity would work with a "Sphered Car" as the arm that sticks out to the right, could be supported on an axle stand, or similar when the height of the car is adjusted.
ACTIVA
CGATCX25GTITURBO
- x 15
