My C5 has started making sqealing noises (a bit like finger nails on a blackboard) after you get out of it. The suspension rises as you get out followed by falling back to normal height, that is the bit at when the noise is apparant.
Testing the car by changing suspension height when stationary showed that the noise only comes on the down cycle when the suspension has been above normal height.
Has anyone any ideas where to look first? It's currently raining so hopefully it will dry a bit this afternoon!
Ben
C5 squeak from rear when changing height
bencowell
Currently driving a 2004 C5 VTR (old shape) and an Electric Kia Soul. Sorry but the electric one is my favourite!
Formerly Hyundai Genesis 3.8 V6, 2 x Kia Optima, 2 x C5, Xsara and Saxo.
- x 5688
bencowell
mooseshaver
Bit like finger nails down a blackboard.bencowell wrote:I was wondering what the sound of arm bearings sound like.
I've had mine greased a couple of times, stops the noise for a while, but the tyres are apparently showing unusual wear, and eventually the tyres will rub on the car.
just hoping it will last till we have finished moving house and we've saved enough money to fix it.
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
Citroenmad
- x 110
What mileage is your C5 got on mooseshaver?mooseshaver wrote:Bit like finger nails down a blackboard.bencowell wrote:I was wondering what the sound of arm bearings sound like.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 5688
Citroenmad
- x 110
Mooseshavers either, I think Bens has around 60ish thousand miles, not enough to need rear arm bearings surely.myglaren wrote:^That's an important aspect - I wouldn't have thought that Ben's C5 would be old enough or have suffered sufficient abuse to have the bearings cracking up.
I have had it with one C5 which made a similar noise, the rear calipers had started to twist causing the pad to rub the disc, as the car raised or lowered when getting in or out the pad made a noise on the disc. Sorting the calipers and pads silenced it.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 5688
mooseshaver
Mine has done just over 30000 miles. Started around 28000. When the rear trailing arm bearings are packed with grease the noise goes away.
I wonder if my C5 was parked in a salty marsh field or something before I bought it. body is fine though, just early death of the bearings.
Gone cars.
Gone cars.
bencowell
I did the calipers the other week and covered the face between the caliper and the hub with an antielectrolytic compound.
I'll jack up the corner and see that they still rotate freely.
My money is on the bearings. One wheel isn't perfectly vertical.
mooseshaver
Re: C5 squeak from rear when changing height
Just had my rear trailing arm bearings repalced. Ahh, silence. And straight wheels. Whoo Hoo!
Only £750 including a service.
While serviceing they dropped the sump, and all was clean in there. But the oil feed pipe filter turbo thing did need cleaned out.
Gone cars.
Gone cars.
Citroenmad
- x 110
It did turn out to be radius arm bearings on Bens C5, surprising at such low mileage.
However the car had previous work to the arms and Ben thinks something had been distrubed to cause the early failure.
Im sure he will be along at some point to update this thread.
Our C5 estate has 78K, it carries very heavy loads everyday and is still on its original bearings, which are fine.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 5688
Mine just passed 147,000 and there is no indication that the rear bearings have had any attention at all. No noises from them either.Citroenmad wrote:It did turn out to be radius arm bearings on Bens C5, surprising at such low mileage.
Will be soon now though, no doubt.
addo
- Sara Watson's Stalker
- x 95
