Xantia Hydraulic Leak
Post Reply
froggy
Donor 2023
My Cars: S2 Xantia Forte 185435.
Peugeot 306 Meridian, the boss.
Post by froggy »
Hi
Just found a hydraulic leak - from around the large internal nut (19mm spanner size) - is there a worn seal inside here
Image[/img]
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
My Cars:
x 92
Post by citronut »
yep just disconect the pipe then remove the addapter/bung, mind not to disturb any of the gubinz under the bung, fit new Oring fit it all back together,
seals and part No.'s below two diferent siezes on any one pump depending on which bung is leaking,
i belive the one you show in the picy is the larger one
4026 87
HYD OIL O-RING
DIAM 16-TO 1,9
- PRESS PUMP 6+2 + NON-SINKING
4026 88
HYD OIL O-RING
DIAM 19-TO 2,4
and below again is price and part No.'s
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000402687 HYD OIL O-RING 1.36 GBP 1.63 GBP 1.63 GBP
0000402688 HYD OIL O-RING 1.16 GBP 1.39 GBP 1.39 GBP
regards malcolm
froggy
Donor 2023
Xantia hyraulic leak
Post by froggy »
Is this a Citroen only part or I get it from a motor factors ?
cheers Terry
Terry
DickieG
Monaco's youngest playboy
My Cars:
x 38
Re: Xantia hyraulic leak
Post by DickieG »
froggy wrote:Is this a Citroën only part or I get it from a motor factors ?
Citroen dealer only.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
Terry, see my recent thread on hydraulic pump re-ringing. It shows one of these exploded.
My Cars:
x 92
Post by citronut »
citroen only as then you know the O ring/s will be OK with citro blood (LHM),
regards malcolm
HDI
My Cars:
x 7
Post by HDI »
Normal Nitrile O rings are fine with LHM, it's just mineral oil.
There can be another cause of a leak there, a crack in pump body casting where the outlet valve screws into the pump. It was the cause of the pump on mine leaking from the same area. The crack was very fine and could only be seen after the pump had been removed. Hope you're lucky and it's just the O ring.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
addo
Citroën Berlingo
Alfa 147
x 93
Post by addo »
Your mode of failure was interesting, because the plugs appear to be installed with some sort of impact/pressure tool. Normal T-50 bits in a ratchet just want to climb up the splines and burr the capscrew - I used the "Attack Driver" for R&R; it came out looking OEM and no leaks.
Stepto1
My Cars:
Post by Stepto1 »
I've had two leaks from the pump now. The first was from the pipe you can see in the first pic. Tried to tighten it but just made it worse. Took and it looked fine. Refitted it and I had a green fountain! Ended up buying a new pipe from the dealer and fitted it. Noticed a couple of the clips were missing so 'found' some. No more problems there.
Next the rubber pipe from the tank split at the pump end. Just cut off about an inch and refitted it. Really needs a new one now as the angle is a little accute where it joins the pump. [/list]
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
Post Reply
