After a couple of weeks of driving i've decided the bone shaking is doing my spine no good so decided to take a look today and as far as i can tell it only the rear near side that has no movement when bounced upon. Its as rigid as a rigid thing so was hoping for any ideas of what it could be.
Help with cushioning.
Foggyoutcome
As some will know from my intro i have a problem with the suspension.
- x 1450
- x 94
Old-Guy
- x 24
Definitely just one 'corner' sphere, but that probably means that all 3 rear spheres need changing. This will transform the ride.
By way of explanation, the spheres are combined gas spring and damper.
About £23 each from GSF and you'll need a couple of Litres of LHM - a 5L can usually works out cheaper than 2 x 1L bottles.
I did a write-up after I did mine the first time (with the benefit of the advice of forum members) you can find it here. Soaking the joints overnight with proper penetrating fluid (not WD40 or similar) makes the job soooo much easier.
Foggyoutcome
Foggyoutcome
I bounced on the corner that was stiff last night and today it seems to of freed up allot. The timing was also out to and i rectified and noticed after the suspension was working ok, i wonder if that is at all possible.
If any one with the knowledge could answer me on that i would appreciate it other wise it was down to me bouncing on it.
- x 94
the only think i can imagine to cause intermitent stiffness (oooh eeer) to just one side is rear arm bearings,
timming wont affect/cause this,
the only other fault can cause intermitent stiffness is the hight correcter linkages/turrets being seized, but this will affect both sides the same on one/either axle, and cannot cause just the one corner to be hard/firm,
what year and modle/engine/badge is this car,
regards malcolm
regards malcolm
Foggyoutcome
Old-Guy
- x 24
I think you have to get your head around how the suspension works.
The spheres are gas springs/dampers. The hydraulic system in effect provides a solid, but infinitely variable, link between each wheel and its sphere.
The height adjusters, front and rear, in effect vary the length of those (hydraulic) links. If the adjusters responded instantly, the car would bounce up and down like a demented yo-yo, so the self-levelling is designed to respond relatively slowly.
When the engine starts, it may take 10-15 seconds to bring the hydraulic system up to pressure (depends how much loading/un-loading has happened since the engine stopped) and then the self-levelling starts to work. The self-levelling should work even if either/both spheres on an axle are 'flat' (no gas and thus solid spring) with the tyre(s) providing the only springing. Driving around like this will damage the car.
It's perfectly normal for the suspension to sometimes go up or down when the engine is started - if the hydraulic system is in good condition, the rear height is capable of self-levelling several times after the engine has been switched off.
Foggyoutcome
Foggyoutcome
- x 94
Foggyoutcome
