3.5mm Flare Tool
Buchan Loon
3.5mm Flare Tool
Unread post by Buchan Loon »
Does anyone have a 3.5mm flare tool they'd be willing to lend/hire out?
Wife's car has a couple of burst pipes that run the length of the car. Was going to buy ready-made pipes but it would be much easier just to replace the corroded sections which means flaring pipes on the car.
Plaedies don't sell the tools any more. There's one on ebay but I'm not the only person after it!
1999 Xantia 2.1 TD SX
x 8457
They're like rocking horse poo...
The problem is that they are a precision item and very expensive to have made in small numbers...
Best might be to visit Pleiades and have him make the pipes up for you...
Buchan Loon
Only slight issue being I'm 475 miles away in NE Scotland!.............. :)
x 8457
Buchan Loon wrote:Only slight issue being I'm 475 miles away in NE Scotland!.............. :)
Ahh :oops: he does a postal service.
Tell him the lengths you need and he'll pop them in the post. Watch the postman arrive with a very long, thin parcel :lol: :lol: :lol:
Buchan Loon
But it would be much, much easier to replace only the corroded sections using a female/female coupler which means being able to flare the existing pipe on the car where I chop it
Anyway, thanks for the replies - I thought you were taking it easy on the boards for a couple of weeks? Can't stay away? :D
x 8457
Buchan Loon wrote:I thought you were taking it easy on the boards for a couple of weeks? Can't stay away? :D
It's Sunday :D
I'm only here just catching up before off to Stratford for a couple of hours and then back to attack a pile of email....
Then it's back to the normal grind :evil: :evil:
x 94
Unread post by citronut »
i have not found the hand held citroen 3.5 flairing tool i have likes steel pipes, as it dosent seem to grip them like it does kunifer even after cleanning all the black powder coatting off,
regards malcolm
davetherave
x 4
Unread post by davetherave »
Not sure if i have suggested it before but perhaps a flare tool location map would be useful?
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
dnsey
x 19
Unread post by dnsey »
Probably a silly idea, but...
A proper Citroen flare is obviously required where the pipes have to fit other components, but could you use a more common pattern for the straight pipe repair couplings? Perhaps ask an industrial hydraulics specialist for advice?
Buchan Loon
Dnsey,
Not such a silly idea as I'd considered it myself, but Citroen have opted for an obscure pipe size. Standard fittings appear to come in 1/8" (which is too small at 3.175mm) or 4mm which will probably be too big.
I am probably in a position to do some experimentation, can any one tell me what sort of pressures the hydraulic system can produce?
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Buchan Loon wrote:I am probably in a position to do some experimentation, can any one tell me what sort of pressures the hydraulic system can produce?
IIRC the pressure regulator cuts out at around 170 Bar so you'd need to allow it to take the best part of 200 Bar to allow a safety margin, can copper pipe take such a high pressure?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1484
Unread post by xantia_v6 »
Buchan Loon wrote:Dnsey,
You should be able to make a sleeve joint with a couple of inches of larger pipe which has an ID to just slip over your 3.5mm pipe. Fill with braizing or silver solder.
davetherave
x 4
Copper pipe can take the pressure, at least to the steering rack, as i made up some copper pipes for mine.
GPZ500s
xmexclusive
Unread post by xmexclusive »
I decided not to risk copper pipe for the Citroen high pressure lines as it is not rated high enough. Ideal for replacing complex brittle rubber returns though.
John
Xmexclusive
