406 HDi Wipers
DHallworth
x 162
406 HDi Wipers
Unread post by DHallworth »
On the way home from work last night the wipers on my 406 started playing up.
They were on position two so constant but not fast then all of a sudden they stopped half way up the windscreen.
I switched them off and then flicked them into the wipe once position and they went for around 10 - 12 wipes and stopped in a random position on the screen.
Intermittent wipe doesn't seem to work at all and when washing the windscreen the wipers will go for around 10 - 12 swipes and just stop again randomly.
When they start to go nuts I can hear the relay above my knee click and I can hear it click again when they stop.
Anybody got any ideas? With the weather we're getting in Glasgow at the moment I kinda need the wipers working 100% really!
Thanks guys!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1240
Unread post by Peter.N. »
Hi David
It it an Hdi? Sounds like an electronic fault rather than a mechanical one. If its a late one its probably got multipex wiring and will probably need the fault codes read.
Sorry, I just noticed the header - it is an Hdi :oops:
DHallworth
x 162
Hi Peter,
It's a 99 V registered car.
It is however a D9 model it doesn't have multiplex wiring or a rain sensor.
Might try and stick it on the Lexia tonight and see what comes back.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
DHallworth
x 162
Well the cars been on a Lexia and there's no fault codes stored.
Have spoken to my friend who has worked at a dealer for over 20 years who has told me it'll either be the motor or the BSI.....
God I hope it's the motor!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Ian63
Re: 406 HDi Wipers
Unread post by Ian63 »
I've got this on my 306hdi (01) no f/codes either, i replaced the motor (as people on another site said all the controls for the speeds were inside it)....didnt work!....I'm putting it down to the switch, I say that because I havent fixed it yet :oops:
DHallworth
x 162
Re: 406 HDi Wipers
I changed the motor in my 406 and it solved the problem completely.
My brother had the same problem on his W reg 306 HDi Meridian, he changed the wiper motor on that and it solved that too! It seems to be a common problem so it's possible you've got another faulty motor!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
