I had to get rid of my red txd 1.7 bx. Its at bullwinkles
I have now got a renault Laguna 1.8 16 valve Exspression.
Its the toxic fume filter system warning light.
Which is next to the abs light It keeps flassing it does. Then it goes off. The car feel lumpy low powerd at times. At low revs. When its on tick over the engine rocks it does. As if its a old diesle engine. But its a 1.8 16 valve petrol.
Its still on warranty I bought it on Tuesday. Got 1 month left
I took it in they said they cant see anything. Unless the light stays on
Toxic fume filter system warning light
Ross_K
- x 110
R9UKE
- x 3
Ross_K
- x 110
R9UKE
- x 3
SaabC5
jacksun1987
So its deffently a ignition coil.
If i went to where i got the car from. Glass house cars in anick lincolnshire. And said i want a new igntion coil.
If they like fob us off saying. Well we checked it it diddernt trune up and all of this s**t.
Whats the best thing to say or do to them.
http://www.glasshousecarsales.co.uk/
They must be doing some good. Becase everyday i drive past. And been in a couple of times. And they always have differnt cars in there.
jacksun1987
Ross_K
- x 110
R9UKE
- x 3
SaabC5
They're not cheap, £100 plus from memory. I lucked out and found a scrapper that had 4 fitted by the previous owner, i fitted them to my Laguna 1.6 16v and they are still going strong and providing slightly more power as well.Ross_K wrote:Interesting. How much would one of those set you back?SaabC5 wrote:even better if you can afford it Renault Motorsport coils which are uber reliable.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
jacksun1987
THANKS
yes it is the renault laguna ignition coils. Ive been on ebay they are 35 pound for a set of 4. I had it checked out and the garuage said the same thing as you.
I then phoned up the place where i got the car. He said hes only got 1 ignition coil. Then i said cant you get all of them. He said it will cost me more and you more. Its under warrinty. Its a 50 50 one. So i bet ill have to pay for half.
Why cant i just buy a car and have no of theses problerms with gauarges and warrentye s. Does my (-expletive removed-) head it it does. Ive had 3 cars now what ive had problerms with. Now it looks like this will be number 4 if im not carefull.
jacksun1987
http://www.ebay.co.uk/sch/i.html?_from= ... Categories
Are theses what i should be looking for
thanks
thanks
R9UKE
- x 3
You don't need to buy all four. Buy one and just change the faulty one! It's easy to identify as the engine note will change considerably, and the car might even stall when the plug is removed to one that's working correctly.
When you've paid considerably more than the car is worth you should have got a fully comp warranty... for a year!
French is best.
jacksun1987
