zx clutch sqeal !
froggy
(Donor 2026)
x 4
zx clutch sqeal !
Unread post by froggy »
Hi. my 1995 zx , has developed a nasty , very loud clutch sqeal, only makes the noise when the clutch is depressed. any body got any ideas? cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
spider
x 77
Unread post by spider »
Its probably the release bearing dried up. A new one or a new clutch assembly will be needed.
The clue here is the fact its only noisy when you have depressed the pedal.
Andy.
froggy
(Donor 2026)
x 4
zx clutch sqeal !
How difficult is it to fit a new clutch assembly ? never done this sort of thing before. is this a garage job ? many thanks Terry
Terry
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I wouldn't rate a DIY clutch job as easy. You have to remove the gearbox to access it, so that requires both some decent kit, a suitable working space and a little time up your sleeve.
As to possibility, it therefore depends on your facilities and prior experience. :)
