Handbrake cable touching tyre R/Side
jimmydod
Hi all have just had a problem with my handbrake fixed that but noticed that cable is rubbing tyre on right hand lock. car Xantia 2.0 HDI. When I got the car two years ago noticed same renewed cable now that is rubbing checked the routing all ok. Has anyone had same problem and how did you stop it.
Regards Jim
Regards Jim
jim the geriatric
Chris570
- x 36
jimmydod
Handfbrake cable touching tyre
Hi thanks for the reply, yes it does have the hoop bolted to the hub and a plastic insert in that too.
regards
regards
jim the geriatric
Chris570
- x 36
jimmydod
Post subject: Handbrake cable touching tyre R/Side
Hi Thank you for your reply, How do I show you a picture?
Regards Jim
Regards Jim
jim the geriatric
- x 94
reblack68
Chris570
- x 36
Xaccers
- x 186
Re: Post subject: Handbrake cable touching tyre R/Side
This explains how:jimmydod wrote:Hi Thank you for your reply, How do I show you a picture?
Regards Jim
http://www.frenchcarforum.co.uk/forum/v ... hp?t=35470
May be a daft question, but the handbrake cable is going through the loop isn't it?
DIY sphere tool
DIY sphere tool
jimmydod
Hand brake touching tyre
Hi all I hope these pictures work, Yes cable does go through the hoop. please note I have put some heat shrink on to protect the cable in the short term
Link http://s1199.photobucket.com/albums/aa465/Jimmydod/
There are a couple of views not terribly clear though. I feel that this cable is too long went back to factor and he assures me it is the correct one ie for Xantia 2.0HDI 90hp.
Dont feeel twisting trhe loop on hub will help it will just kink the cable.
Regards to all [/img]
jim the geriatric
Chris570
- x 36
i think you're right in the cable being too long, it is def about 2-3inches too long. I'm wondering if either the motor factor has given you the wrong side and also heard "HDI" and presumed its the 110 version which has the longer cable (but not on that side)
i presume the cable is nice and snug elsewhere and that although it touches the tyre works ok? (not saying its ok to leave as is just making sure its seated properly)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
jimmydod
hand brake touching tyre
Many thanks for your reply Chris560
I shall go to another factor and see if I can get a shorter one, will also look online ot other brake part suppliers.
many thanks to all Regards
jim
jim
jim the geriatric
jimmydod
Handbrake touching tyre
Sorry Chris570 I said you were Chris560 (the extra 10 must be important) I also need to reply to your mention is the cable snug I can confirm that.
Kind Regards to all
Kind Regards to all
jim the geriatric
jimmydod
Hand brake cable touching tyre
Hi all
Have been on internet and spoken to a very helpfull man from AEP their r/h xantia CABLE IS 1333MM LONG ALSO COMPANY i BOUGHT ORIGIONAL ONE OFF IS 1335MM long. He (man from AEP cross referenced genuinc Citroen part number and that he said was 1333mm long. Could it be the alloy wheels somehow is wider that origional steel wheels, these I believe were off a Citroen Xantia but a more sporty variety, howeveer they have the same tyre size as my steel origional. Am now getting desperate as mot is imminent.
Regards to all
Regards to all
jim the geriatric
Chlorate
