The front windows have an intermittent electrical fault. O/S window drops down ok but the closing goes in short bursts. Pressing the control button sends it up again for a few more cm's and so on until it finally closes.
The n/s window is usually fine but there was no response when operated from the o/s door button. Drivers side button did close it in one go.
So - where do I start? Is this something easy to fix or one for the local elec specialist?
I read elsewhere that high mileage cars have an earthing problem (corrosion?) - mine is definitely in that bracket.
Hope it can be fixed simply - any suggestions greatefully received!
Nigel
PS just returned from a holiday in Herefordshire. Xantias everywhere - even had an unofficial convoy with two V Reg Silver Estates through Peterchurch.
Xantia Estate Front Window Fault
NAM
NEW 50 Shades of Grey C5 Tourer 2016 BlueHDi 2L VTR+
C4 (62) 1.6HDi VTR+ (Feb 2020)
Silver Dream Machine: C4 Hatchback, 1.6 SX HDi (07) (July 2013 - Feb 2020)
C5 Tourer Exclusive 09/2Ltr HDi (Oct 2012-Sept 2021 146K miles
Xantia Estate Mk2 1.8LX V-Reg/2000 173K miles.
jgra1
- (Donor 2021)
- x 36
Chris570
- x 36
mine does this, if i'm driving along and i open the window it'll be fine no matter how many times its used. the problem is actually when i open the door, its as though opening the door makes the anti-pinch system 'forget' its settings so it has to go back up in short bursts (as after a battery disconnect) my theory is a dodgy wire in the door shut that makes contact most of the time.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
