anyone fitted a saxo cd player to a Xant??
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
Morning all!
Been nosing about and though id see if any of you have fitted a saxo,berlingo,style cd player to an s2 xant with any degree of success??
player in question is as below,
http://www.ebay.co.uk/itm/200645128780? ... 1436.l2649
'58 C2 Code
'58 partner teepee outdoor
Chris570
x 36
Unread post by Chris570 »
well you could, but why
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
Timmo
(Donor 2022)
x 168
Because i only have a cassette head unit in it and no cassettes!! :D
'58 C2 Code
Chris570
x 36
for the hassle it'll be to change the head uni i'd rather put a decent one in.
yes it'll work but only to a point.
get an aftermarket one with steering wheel controls and you're laughing
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Sony MP40 is a reasonable headunit that will go in, and work with the controls (using some extra link cables) . plays MP3 cd's :twisted:
there was another sony that would go in CDX50 or something.. and probably these days a whole load more units from different manufacturers, that may work :D
you wil need a £2 blanking plate, as the original unit is bigger than the standar DIN size
hope that helps
J
Ross_K
x 110
Re: anyone fitted a saxo cd player to a Xant??
Unread post by Ross_K »
Timmo wrote:Morning all!
They were fitted as standard to some later Xantias, so it shouldn't be too much of a problem... Some of the ones you find on ebay won't have the connector on the back for the steering wheel controls so ask before you buy. 8-)
x 2941
That is the actual unit fitted as original equipment on my 2001 Xantia Forte 2.0 HDI, it should plug straight in, the options were that or the cassette or the six pack in the boot.
Timmo
(Donor 2022)
x 168
Thanks guys, much appreciated,
i looked at the sony hu before, not my cup of tea, when i had tihe silly system in my 309gti and the bx was a kenwood hu man, :wink:
Is also the difference between £20 or £50-70 for a decent used hu, plus £30 for the patch cables and fascia!
I'll ask about remote cable controlls on the ones I've saved :wink:
'58 C2 Code
