hub nut size
Chris570
x 36
hub nut size
Unread post by Chris570 »
on the front hubs of a xantia (i presume they are all the same, if not its for a 1998 activa)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
36mm in sure is the size....
Paul
A very sad...
1994 XM 2.1 d auto
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I've had a 1 3/8 (12 point) socket on there - maybe it's just sloppy enough to make the extra mil?
x 1504
For reasons best known to PSA it's actually 35mm.... A 36 six pointer will fit OK.
Ah, actually 35mm is pretty close to 1 3/8" AF so that's probably it. I wonder if the thread is actually an imperial one???
citroenxm
Fallen Hero
x 70
I said 36 as that was the only socket I could get to fit....
35 real size as already said..
Paul
A very sad...
1994 XM 2.1 d auto
x 8457
Chris, be warned that those nuts can be FT sometimes.
Use a steelie wheel to provide a torque counter if the handbrake won't hold when trying to undo the nuts.
If you do use the handbrake and the wheel is off, do replace the wheelstuds or you'll shear off the small grubscrews holding the disc on...
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
CitroJim wrote:If you do use the handbrake and the wheel is off, do replace the wheelstuds or you'll shear off the small grubscrews holding the disc on...
How do you know that? :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8457
Let's just say I do know :oops:
Chris570
x 36
i have to say i've always found them to be a lot less tight than AX/Saxo ones...
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
Toby_HDi
x 3
Unread post by Toby_HDi »
Chris, where are you?
I've got a 3/4" drive 35mm socket on the end of a 4ft torque wrench you're welcome to borrow.
Me and Kev also roughly tested its calibration using his XM hub nut and it is very well calibrated so useful for doing them up again.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Chris570
x 36
i'm up near jim so a bit far, thanks for the offer though :)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
dnsey
x 19
Unread post by dnsey »
If they're really tight, you can set things up so that the bar is against the ground, then drive slowly in the appropriate direction - that shows them who's boss...
x 94
Unread post by citronut »
i usualy tap a large old screw drive blade into one of the vent slots in the disc (not to hard a tap either ) , and as Sir Jim says wind a couple of wheel bolts in most of the way,
this way you dont have to worry about the wheel turning,
regards malcolm
KennyW
x 165
Unread post by KennyW »
Chris,
I've had my hub nuts off :wink: my xantia very recently and I used my breaker bar with scaffolding pole 6' to loosen them. I used the car wieght as the counter balance. This has never been a problem.
Kenny
C3 1.4 petrol (SWMBO)
x 1955
Unread post by Paul-R »
