Clips - Engine covers and trays
frenchcarnut
Unread post by frenchcarnut »
When I cleaned the engine cover during the oil change I did yesterday, I noticed it was free of the engine with the clips on!!!! Basically the rubberised shafts of all but one of the retaining bolts had sheared (Edit - these are referred to as dampers). Is this common?
Here are the clips, but their corresponding retainers (Edit - or dampers) are shafted ;-):
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0682654231
Edit - just found similar on ebay http://www.ebay.co.uk/itm/PEUGEOT-HDi-E ... 4cf7958253
I've also lost a few retainers from the "engine undershielding" These are the slotted mushroom headed clips (called buttons) that have grab shafts. I don't know if we're meant to push up and twist these by just a few degrees (tend to push and twist 45-90 degrees), but I've got only a few left out of how many? (Edit - Should be 6). Of course the 4 small bolts that do the bulk of the retaining are fine (Edit - should be 6 of these also).
04 C5 2.0 Auto HDi VTR
frenchcarnut
Here we go:
http://www.ebay.co.uk/itm/CITROEN-C4-C5 ... 4cf3279cd9
Just need to source the undershield clips.
frenchcarnut
Quite a common problem according to Citroen Brum. Loads in stock at £4.79 each for the dampers and £1.79 for the clips. The above kit seems a good choice.
x 2943
I bought a set of those for my C5 last week seem ok so far.
What I need to finish this car is the undertray from under the engine, it was missing when I bought the car and seems pretty difficult to find in the breakers.
frenchcarnut
Gibbo2286 wrote:I bought a set of those for my C5 last week seem ok so far.
I wonder if there are loads of oily undetrays in people's garages - left as awkward asides from various oil changes?
HDI
x 7
Unread post by HDI »
If there are I would like one please !! The engine undertray doesn't need to be removed for an oil change, there is a little hatch for access to the drain plug and the filter is removed from above.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
frenchcarnut
HDI wrote:If there are I would like one please !! The engine undertray doesn't need to be removed for an oil change, there is a little hatch for access to the drain plug and the filter is removed from above.
Is that right? Never noticed (duh). Perhaps because of the amount of oil :lol:
Will take a look. But how do you get the oil to drain? Funnel? If it's awkward, then I'm happy to take the undershield off once a year.
frenchcarnut
Pretty certain there's no flap on my undertray which has to be removed to facilitate oil change.
x 1430
No flap on either my Xantia or Picasso. Both undertrays are in the garage, the fasteners having rusted up (Xantia) or failed (Picasso). My earlier Xantias did have flaps but they were front hinged so a right PITA to operate when changing oil on the drive, rather than on a 4 post lift :roll:
x 1238
Unread post by Peter.N. »
I replaced the ones on my 406 when I first had it with some from ebay - they lasted about three weeks.
Clogzz
x 40
Unread post by Clogzz »
The buttons with grab shafts ... item 10 part 703016 ... must be firmly pushed straight in without twisting them.
Turning by a ¼ turn loosens them.
C5’s don’t have flaps.
2002 C5 2.0i AL4 239,000 km 76372389
x 2943
I haven't got a flap, I haven't got a tray :cry:
It seems that they either get thrown away by "that's near enough" mechanics or they're the first thing wrecked in an accident.
x 94
Unread post by citronut »
i find doing an oil and filter change with the tray fitted makes one heck of a mess,
regards malcolm
frenchcarnut
Peter.N. wrote:I replaced the ones on my 406 when I first had it with some from ebay - they lasted about three weeks.
Well they can have 'em back if that happens to mine!!!
frenchcarnut
Clogzz wrote:The buttons with grab shafts ... item 10 part 703016 ... must be firmly pushed straight in without twisting them.
My retainers are probably worn then. I shall purchase those too.
