Xant Wipermotor replaced caused electrical fault-tick tick
magictorch
Unread post by magictorch »
I swapped over my wiper arm motor/linkage on my Xantia this morning. Tested and all worked fine. Having replaced and sealed the scuttle trim then attached wipers I checked to see if they swept properly. On turning the ignition there is now a tick tick tick
The ignition will not start, electric sun roof is stuck. I plugged in the old wiper motor to make sure the new one was not causing the issue same problem.
What could cause this? I need to get my windows closed as its going to rain tomorrow.
Cheers
Jamie
magictorch
If this helps the Xantia is a 1996 Estate. I am unable to locate the wiper relay to eliminate if this is the problem. Is it mounted behind the plastic trim on the left of the wiper linkage bay?
Jamie
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I take it it's not something as simple as with your wiper testing you've flattened the battery?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
magictorch
Hiya, No battery is fine.
Sorry if this is a running commentary.
I have now tracked down the intermittent relay for the wipers. Having unplugged this the fault continues.
Listening to the ticking and where it comes from I tracked the fault to a small black box labelled "relais protege" right next to the battery. Disconnecting this the ticking stops.
I am unable to turn the car over what is this box and what does it do?
magictorch
SORTED
Found the problem it. In leaning on the car battery I have slightly damaged one of the earth leads on the chassis mount. The brittle old cable is now patched up and all is running!
DickieG
x 38
Hurrah :D
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
magictorch
Happy sunny days. I would still like to know where that wiper relay is though!
