'86 BX 1,9GT Lego - just found out that the vacuum advance isn't working because the diaphragm's had it.......will it never end???[:o)]
Now I remember you used to be able to get the Bosch capsule unit on its own - is that still possible, and what info d'you need to match it up to the specific car? IIRC they're pretty standard but I'm probably wrong (again).........[xx(]
Distributor Vacuum Capsule - Jon?
Jon
alexx
About 4-5 years ago, when I had that problem (BX16 '89), Bosch vacum diaphragm was available as a separate part, but mine (Ducelier) wasn't, only complete distributor, costing about 200 DEM. I bought Bosch diaphragm (about 50 DEM) and combined it with the old one. It took about 3h of work. The system still works (well, its characteristics are slightly different than it should be, but who cares).
Linegeist
I suppose if I REALLY wanted a challenge I could always make up a diaphragm......
I had a particularly inventive Corporal many years ago in Germany who, whilst on exercise, fixed a vacuum advance capsule on a Bedford 3 tonner using a condom of all things!! I was assured by my MT Sergeant that the vehicle wasn't totally 'screwed up' by this ................... [:0][:0][:0][:D]
