C5 'Airbag fault'
C5 'Airbag fault'
I've had that message on my screen since I bought the car, think it might be time to fix it, any suggestions before I start digging?
viorelovidiu
Re: C5 'Airbag fault'
check for burned wires and/or loose connectors. which one is faulty?Gibbo2286 wrote:I've had that message on my screen since I bought the car, think it might be time to fix it, any suggestions before I start digging?
mine is (not yet fixed) lateral side airbag faulty and I`ve found the wires with burned isolation all the way under floor carpet to the central console. I have replaced entire burned section but not luck... I have to remove dashboard
Citroen C5 2005 2.2 HDI 136cp Exclusive BVA
EX: Citroen C5 2005 2.0 HDI 138cp Exclusive
EX: Citroen C5 2005 2.0i 143cp SX
Clogzz
- x 40
viorelovidiu
Citroenmad
- x 110
Its often caused by the wires wich run under the passenger footwell. If you life back the carpet on the passenger side floor, remove the foam block at the front and there you will see a selection of wires.
I had this on a previous C5, I took the connectors apart, cleaned them with contact cleaner and repositioned, as best I could, the wires away from under the foam block. It seems to happen at first when passengers are in the car with feet on the block. Mine did not appear again after doing this.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
birstall
