ref fitting activa turbo bumper to mk1 td
modxl
Unread post by modxl »
got hold of what i believe is a brand new mk1 activa front bumper went to fit it today to my td and it seems to be a bit wider on the side and not line up with wheel arch.Question is did mk1 ativa turbo have slightly different front wings,seem to remember reading somthink once but cant remember were
many thanks steve
xantia td
soon full leather
rear spoiler
Xaccers
x 188
Unread post by Xaccers »
Yes, Activas, and I believe V6/2.1TDs as well, had wider wings.
DIY sphere tool
modxl
that explains it now got to find a set of wings,anyone got any ideas were ill find a set,i take it mk2 wings are different
xantia td
soon full leather
rear spoiler
Xaccers
x 188
Yeah, unfortunately MK2 wings are different, I can't remember if they can be made to fit or not though, if they can then they'd do.
DIY sphere tool
modxl
cheers mate i thought mk2 were wider,i think its just indicators that are different on them have to go and have a look at locol scrap yard and compare some
xantia td
soon full leather
rear spoiler
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
S1 2.1, V6 and Activa wings were wider..
BUT Hold on!!!
S2 wings to nose cones differ!! Because S2 grill are incorperated into the bonnet, the under headlight trims are a seperate peice instead of a complete single piece as on S1. S1 Grill cones have a torx screw holding the trim edge to the wing, and S2's use a CLIP! They dont appear compatible...also S2 under headlight trims clip to the side of the headlight which are obviously shaped differently.
The shape of S2 indicators ARE different, S2 headlights/indicators are shaped at a steeper angle for a slightly better streamline, meaning they will NOT line up with S1 headlights... If you fit S2 headlights, you'll need to change the bonnet, and then also the Slam Panel..
I wouldn't bother trying to mix and match S1 and S2 stuff, it can get messy. You will have to find Series 1 V6 or 2.1 or of course Activa Wings.....
EDIT: ** SO Im prooved wrong...........!!!
Paul
A very sad...
1994 XM 2.1 d auto
x 8457
Xac wrote:Yes, Activas, and I believe V6/2.1TDs as well, had wider wings.
You are spot-on Xac. The MK1 Activa, V6 and 2.1TD all shared the same 'fat' wings...
andmcit
x 30
Unread post by andmcit »
The wing mod has naff all to do will grille/indicators/lights/bonnet/trim strips!
I've fitted a s2 fat wing on a s1 Activa with NO real issues.
There's a tab on the leading edge of the s2 wing (inboard) that needs removal
(very easily done as very light gauge) that slots into the headlight panel.
You never see it as it's hidden behind everything so even if you just bend
it to/fro and work harden snap it off, it's not needed on the s1.
ergo:
s2 wings will fit the car you're upgarding to an Activa 'look'
The original grille and indicator + fastenings are then exactly the same set up.
Nothing moves you like a Citroën
modxl
cheers for that as long as you are sure ill have a go,can get series two wings for a tenner each at my local scrapy,not trying to make it look like a activa it was new bumper from citroen for a tenner as mine was cracked,like the shape better as well.
xantia td
soon full leather
rear spoiler
Citroening
x 19
Unread post by Citroening »
modxl wrote:it was new bumper from Citroën for a tenner
I see you're in Cambs - was it Borocars in Peterborough? :?:
Franklin
