Rear Xantia suspension problem
nick90
Unread post by nick90 »
Wel lads,
I have a problem the housing that the sphere is screwed in to on the rear near side is wobbling around i think there is something missing. but i'm not sure
and i can get the sphere off it wont budge. i've tried everything
3ft stihl, strap wrench, and 3 other oil filter wrench.
help need urgently. pictures would help
Nick
Citroenmad
x 110
Unread post by Citroenmad »
Are you trying to untighten the sphere with the car in low/pressure off?That will make the cylinder loose. If you slacken the sphere off with the car in high or normal height and then lower it to remove the sphere totally.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
