Oil in water tank
flashgit
Oil in water tank
ok guys. i bought a Xantia Td. all seemed ok when i checked it. noticed when i got home that the expansion tank has thick oily fluid and not water or coolant. car does not seem to over heat or anything. what's the cause?
wotwot
- (Donor 2021)
- x 4
addo
- Sara Watson's Stalker
- x 95
Not so good! I have this on one car; the engine oil cooler has corroded inside and oil (80PSI) forces its way into the coolant (14PSI).
Best to fix the cause ASAP and then comprehensively flush the coolant, as leaving too long will cause the hoses to be dramatically weakened - leading to failure after failure. Been there, done that as well.
- x 94
VertVega
- x 13
Re: Oil in water tank
Just a "silly" questionflashgit wrote:... the expansion tank has thick oily fluid and not water or coolant. ...
Is the tank (which you called expansion) located on the left side, behind the battery?
Could it be the LHM tank
- x 94
VertVega wrote:Just a "silly" questionflashgit wrote:... the expansion tank has thick oily fluid and not water or coolant. ...A crazy thought came to my mind
regards malcolm
- x 2941
Xantidote
- x 5
