1st MOT Failed
hdi_man
1st MOT Failed
Unread post by hdi_man »
well MORE problems....
2008 C5 hdi exclusive, 32k miles.
into dealer for basic service & MOT, just got call....failed MOT and £870 to fix everything...
- new rear discs & pads
- suspension droplinks
- front ball joint
told them NO way and just paid £140 for basic service & MOT fee. they will re-test for free within 10 days.....no I just need to fix the stuff !!! :?
I'm tempted to get it all done and sell it....or just trade it ASAP.
honestly Citroen aren't building these cars properly - its a piece of crap
wotwot
(Donor 2021)
x 4
Unread post by wotwot »
Thats steep have you checked the price of parts from GSF europarts or a motor factors parts should'nt be more than £200.
3 hours labour at the most £90 per hour surely.
Where abouts are you.
I'm sure there are forum members here would help to repair for beer tokens
and tea and biccies.
If your close enough I will.
handyman
Unread post by handyman »
Why does this car need new rear discs and pads on 32K miles? That is hardly any mileage for an item that gets very light use.
Equally, if it were mine, I'd complain to Citroen over the mileage that the worn compenents have done.
You will probably find an indy workshop would charge considerably less than £870 for these parts that are very easy to fit.
Whereabouts are you as we could probably recommend a decent garage to do the repairs?
Handyman
hdi_man
I'm in Glasgow.
no idea why it need rear pads but they are metal to metal and making a noise when I brake.
I put it down to the fact the car is too heavy and they are using parts from probably a C4 !!! :roll:
wotwot
(Donor 2021)
x 4
If I caught the train there and back I could still make a tidy profit on what they want to charge.
hdi_man
exactly , thats why I told them where to go !!
Ross_K
x 110
Unread post by Ross_K »
hdi_man wrote:I'm in Glasgow.
Get a price from Citroen Services on the Cambuslang Rd. in Rutherglen. I've always found them to be very reasonable in the past. Tony's the guy to ask for.
Not affiliated with them BTW, just a former happy customer.
Ross_K
x 110
Just did a google - they're on Farmeloan Road now. Number is 0141 647 0542
HDI
x 7
Unread post by HDI »
They're not called main stealers for nothing !!
That quote is absolutely outrageous !!
As mentioned above, 3 hours labour + parts should do it.
Discs and pads probably £100 max for the pair, drop links £15/pair, ball joint £15 max. So, £205-225 max depending on the labour rate.
Even if we were generous with the dealer and allowed for double that, they are still taking a mighty p155, but at almost 4 times it's almost robbery !!
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
JohnD
(Donor 2022)
x 72
Re: 1st MOT Failed
Unread post by JohnD »
hdi_man wrote:well MORE problems....
They're wanting to rip you off. Either that or your car has done a lot more miles than you think it has. Could that be possible? Just looked at my maintenance records for my C5 which is on 80000 miles. New rear pads at 40000. Still with original discs on the rear. Has just passed MOT with original droplinks and ball joints.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 5688
I'm pretty sure mine is on original droplinks at 145,000.
Balljoints done at around 120,000, £13 each and £25 to fit.
Rear discs done a couple of years ago, £100 inclusive fitting.
hdi_man
are your cars new shape C5's ? I suspect the new ones are not as reliable.
the mileage is genuine as I have full service record. the rear pads are definitely worn through to the metal....maybe its the way I drive ?!?
anyway, local garage is doing all the work for £300 and I will get free MOT re-test at dealers. still more than I expected on a 3 yr old car but thats life !
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
Hang on a minute, When was the car registered, I'm thinking 3 year warranty here......
Ball joints are notoroius for failing on the C6, due to the rubbish (read what you will) design, I'd be really tempted to badger Citroen UK on those along with the drop links.
Rear discs and pads :shock: :shock: JEEZ, some of the dealers are offering to replace these for £215, here is the link
http://info.citroen.co.uk/finance-and-s ... ce-repairs
Steve
http://c6owners.org/index.php
wotwot
(Donor 2021)
x 4
Its a shame you dont want to or cant do the job as you would only be paying about £150 tops.
hdi_man
you reckon £150 for parts and then DIY ? I could do it I suppose...I thought £300 was not bad as I called a few places. I'll get another few quotes
