Bouncy front end - Xantia II
rmunns
x 9
Unread post by rmunns »
'Normal' Xantia II (non activa, non hydractive).
From the service history I think the accumulator sphere has never been changed (11 years, 67000 miles). The front side ones have been changed (30000 miles).
I can't hear ticking with engine running, but then the engine (Hdi) is noisy enough to drown out ticking I think.
I recently replaced all three rear spheres and after that it seems front of car has become more 'bouncy'.
Think I need to replace accumulator sphere. Opinions, please.
Dommo
x 20
Unread post by Dommo »
The accumulator doesn't affect the ride quality particularly, it would affect the feel of the brakes if it was totally flat like the ones were on my 2.1TD and 1.9TD cars.
Sounds like - if the ride height is correct (approx three fingers between the top of the tyre and the arch) - you need to replace the corner spheres. But replacing all three front spheres (corners (strut) and accumulator) would never be a bad thing.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Citroën spheres have a date code stamped on them in black - look for four digits with a pronounced space between first and second numbers. Examples:
1 024 is 24th day of 2001
9 113 is 113th day of 2009 OR 1999 (use commonsense here)
