rear suspension xantia
peter mawer
Unread post by peter mawer »
I had the height selector thingy replaced yesterday (friday) I now find today that I can only get either the lowest or the highest level. Obviously the car is back in the garage Monday. However Is this problem probably connected with the work we have had done ?. Also is it safer to drive in the lower or the higher level?. Cheers Peter?.
blueboy2001
Unread post by blueboy2001 »
Whoever fitted the HC has not connected the linkages up properly and thus the car won't lift up.
Its not really safe to drive it in either position really, as neither offers any suspension movement. If you hit a heavy pothole at speed the car could bounce uncontrably.
Try the position above normal and see if that'll lift the car up.
peter mawer
The car is now stuck at the highest level and will not lower. AAAAAAAAAAAAggggggggggghhhhhhhhhhhhhhhh. Is this the linkages not fitted correectly?.
peter mawer
At least It did work for a day
