Strange thing happened with the HDi today that i have no explanation for!
On a duel carriageway at about 75mph and for no reason the revs shot up to 6000 for a few seconds (bearing in mind the limiter don’t let it go past 5k) and a huge cloud of black smoke belched from the exhaust, so much so I couldn’t see the cars behind me. The residue of the smoke disappeared in a few seconds and strangely the car defiantly felt like it had more power and was more responsive than its been in ages.
Then about 10 mile later the same thing happened again, this time there was a strange clicking sound that lasted 2 seconds just before the rpm to 6000k, black smoke again, smoke clears, then car went like a rocket again.
Car sounds fine, oil ok water ok, no overheating or strange smells, no recent additive to the fuel or the like so any thoughts would be appreciated.
HDI cloud of black smoke?
trooper30
2000 Xantia Hdi
2006 Laguna DCi
2006 Laguna DCi
kraM
I don't know the engine, but... a bit of generic advice
Check the crank case breather system, and air filter / air box intake, as if there is a blockage or damaged connector. As you maybe pulling oil into the intake system, hence the high revs, as the engine will not the the rev limit of the fuel pump.
Have you recently topped up the oil, as if it is topped up too fast, some can work its way into the intake system.
If the above is correct, you're bloody lucky it didn't do it on initial start up or in town, as the engine could have 'run away', which means you and everyone else should run away before it goes bang.
Hope this helps,
Mark
Hope this helps,
Mark
2002 Citroen C5 2.2 HDI Exclusive Estate,
1997 Honda Civic v-tec e, never missed a beat (it is a Honda)
1981 VW MK1 Golf GTi
1999 Triumph Daytona 955i, now gone ;(
1998 Honda Transalp - in a bid to keep my licence...
Clogzz
- x 40
Dommo
- x 20
