obd II compliant??
deano1970
obd II compliant??
Unread post by deano1970 »
hi, following up to my antipollution fault that came on my 406 2.0hdi (2001) yesterday on my way home from holiday, can anyone tell me if the car is obd II compliant? I bought a cheap reader for my mrs scenic and cleared the engine fault light but cannot see where it would plug into my car? it was just under the drivers side with the fuses on her car? the antipollution fault light has now gone out and stayed out but I would like to try and do a code read on it to see if it comes up with anything....thanks,dean.....
deano1970
this is the reader I bought if it helps...ebay number 170430182802,cheers
Toby_HDi
x 3
Unread post by Toby_HDi »
Being a diesel, your 2001 HDi is NOT OBDII compliant. Petrols went compliant in 2001 but diesels not until 2003.
You'll need the proper DIAG/PP2000 interface for yours.
The socket is behind a blanking panel by the drivers knee. Next to the cruise control arming switch or ESP disable switch (depending on when the car was built)
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
dieselnutjob
Unread post by dieselnutjob »
if it has a Bosch ECU then it is EOBD compliant. You can only get the emissions related codes and some live data though.
If it has a Seimens ECU then EOBD won't work.
