When I can bring myself to do it, I will be removing the HCs and the roll corrector from my Activa, stripping them and cleaning them properly.
Whilst they are off, providing the system is depressurised and all open LHM lines plugged is it OK to lower the car to the ground and rest it on its wheels?
I don't want to do it if any damage will occur but equally, I'm not keen on having a car in the road on stands for a few days.
Height correctors
Toby_HDi
- x 3
Height correctors
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
Xaccers
- x 186
Do you have the means to lift it up to refit the hc's when it's done?
DIY sphere tool
DIY sphere tool
Toby_HDi
- x 3
Yes, I'll have to double check but I'm sure my jack goes under even when the Activa is set to low.Xac wrote:Do you have the means to lift it up to refit the hc's when it's done?
Toby
Previous:
Previous:
- x 94
- x 8296
Yep, I agree, keep her up on stands. In fact, the A/S valves will do their job even with the HCs removed, not that you must ever trust them to support it though... It'll make the job much easier long-term.
You'll need a very slim jack with a big lift to bring a Xantia up off it's belly.
One thing to bear in mind, the system will bleed for days on end with the correctors removed so you'll need a big drip tray underneath. The Roll Corrector piping is especially prone to bleeding profusely....
- x 94
