SCENIC II AIR CON BUTTON NOT LIGHT UP OR SWITCH AIR CON ON
gazzas c5
Unread post by gazzas c5 »
Hi folks i got my scenic air con regassed today and then went to try it,the air con button wont light up when pressed even the next same type switch for heated rear window works,I am desperate to get the air con working what do i do?cheers Gaz
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
R9UKE
x 3
Unread post by R9UKE »
Where did you take it for a re-gas? I would take it straight back! Kwik-fit give you your money back if the air con doesn't improve... other places should do the same.
French is best.
