Since I have to change the oil in my 2001 xantia's gearbox (equipped with AL4 gearbox), I was looking for a substitute/equivalent for the original fluid. From Citroen it is outrageously expansive, so, I've found out that there is a Belegian
oil manufacturer named "sunoco" that manufactures "sunamatic atf 155" that is an equivalent to the original fluid (its price here in Israel is less than half of the Citroen's). I also was told by the local agent that it is used in VW (are there any VW's with AL4 gear?). Anybody heard about this manufacturer/product? do you know/recommend any fluid?
Thanks.
Fluid/oil for AL4 gearbox
addo
- Sara Watson's Stalker
- x 95
atr
- x 6
Thanx addo
As far as I know not Total nor Esso are imported to Israel. the original fluid from Citroen costs about $28 per liter and that's why I was looking for an alternative. as I've mentioned before, I was told that the Sunamatic atf 155 is an equivalent to the Esso LT 71141, but I never heard about it.
- x 8302
Clogzz
- x 40
The original oil, Esso LT 71141 has become Mobil LT 71141.
It’s used in Citroën and Peugeot AL4 and ZF 4HP20 boxes.
VW and others also use the ZF box and LT 71141 oil.
Renault uses the AL4 box, but calls it DPO and put Dexron III in it.
Sunoco is an american company and their ATF 155 is a Dexron III.
I got my car at 94,000 km and it didn’t have the LT 71141 in it, and I’m still going at 118,000 km.
I put australian Penrite oil in the AL4 but it obviously comes from another company.
It looks like LT 71141 but doesn’t feel or smell like it, and it doesn’t pretend to last a ‘lifetime’.
Castrol Transmax Z is a certain alternative but it’s also expensive.
lexi
- x 134
I have come to conclusion that the oil is expensive wherever you are BUT it is freely available .
Sometimes it is better to save time, rather than money
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 8302
This thread is a long discussion on ATF in connection with the AL4, the 4HP20 and what is believed to be viable substitutes.
It's worth a read
It's worth a read
mlkey
I have a document from ZF, which lists all their transmissions (including the 4HP20 and 6HP20) and the various oils they can use, but can not work out how to attach itCitroJim wrote:This thread is a long discussion on ATF in connection with the AL4, the 4HP20 and what is believed to be viable substitutes.
It's worth a read
- x 5652
There is no forum facility to attach documents. Can you link to the original?mlkey wrote:I have a document from ZF, which lists all their transmissions (including the 4HP20 and 6HP20) and the various oils they can use, but can not work out how to attach itCitroJim wrote:This thread is a long discussion on ATF in connection with the AL4, the 4HP20 and what is believed to be viable substitutes.
It's worth a read
- x 8302
If it's the same as the one in the linked thread mlkey then it's open to interpretation. Interpretation of the wrong kind..mlkey wrote: I have a document from ZF, which lists all their transmissions (including the 4HP20 and 6HP20) and the various oils they can use, but can not work out how to attach it
Sorry to sound like a cracked record here but you can consult all the lists and recommendations you like but in the end it comes down to one oil only: LT71141. There is no various about it.
